Old Dec 22, 2013 | 12:56 PM
Billy22Bob's Avatar
Billy22Bob
Default Re: Max rpm to redline... 7,000 - 7,500 rpm?
Originally Posted by rcompart
I'd start with the the basics before worrying about bumping the rev limiter.
Thought about this for a mminute....
Why isnt the Rev limiter a basic?
L8tr....a couple of things.
- Its relatively easy: $900 and you have a swap in out TCU with S/W-manual mode to boot.
- Its as plug and play as a pulley change, you can switch back to stock with your old TCU in 5mins.
- If you're starting from basics (stock) - you really dont have to watch your AFR's 'cause your not "stacking mods"
- Assumption - You might not run into some of the walls that have challenged others with this mod when stacked with other previous mods.
- You gain ~10% more air at the top end (negating any significant drop off in VE).
Downsides that make it "non basic"?
