Old Dec 24, 2013 | 02:53 PM
  #787 (permalink)
onehundred80
Default Re: Chrysler to Replace '05 Convertible Tops Under TSB - YAHOO!!
Originally Posted by MRethman
-- even five-minute epoxy needs to cure for many hours to get to full strength.
Regular epoxy is the strongest and takes longer to cure.
All these cars were built in Belgium.
These cars were built in Germany
[QUOTE=MRethman;773131]P.S. Can someone tell me where I can get a single 48" plastic zip-tie to check the slushbox tranny fluid level in my 2005 SRT roadster?[QUOTE=MRethman;773131]
I use a small diameter plastic tube that came with my oil topsider pump kit. The oil goes up the inside and is unaffected by touching the wall of the tranny oil filler tube, just wipe of the outside and you can see the level inside. Keep your finger on the end and it does not drain out.
