D33pak
When I’m driving sometimes and floor it on a straight road and then stop at the lights and then take off as normal (not flooring it) the car red lines but the car does not move, it just revs when I press the gas lightly, and few seconds later it’s back to normal driving.
Ditto on the Bosch v Johnson
This doesnt sound normal - check your tranny fluid, but I'd do a fluid transfusion + filter.
Use a 3ft piece of curtain wire to meaure fluid level - target = 50mm at 80degC tranny fluid temp.
Transfusion - You gotta get under the car (tranny) to get to the tranny sump+filter. There's a good drain procedure somewhere (eother here or over at benzworld/R170) where you simply drain the fluid via your front cooler hoses rather than the sump plug/s.
Takes <2hrs $100 for MB fluid though and $20 for gasket/filter kit.
If not done already
and only do it once - replace ye olde electrical connector and/or o-rings - $10 for the connector plug.
