Old Jan 1, 2014 | 06:09 AM
blueeyes147's Avatar
blueeyes147
Default Re: lowering battery voltage, engine startup problem
Originally Posted by aplusbrian
There may be other on here with better knowledge of your problem but it sounds like your cam shaft of crank shaft positioning sensor is not working properly and causing the ignition timing to be off.
How does it run when it warms up? does it keep back fireing?
does not get better when it warms up I have to use a starter connected to the battery and after several attempts part correctly then it's okay if I continue to use the car as it remains stationary for a few days the problem reoccurs
