Rear License Plate Mounting
I just bought a 2006 Limited Roadster (beautiful, lo-mileage car), and when I went to put the new license plates on it, I found that the rear plate mounts to the rear fascia using just two holes that appear to be drilled directly into the fascia. These two holes are "rather delicate" as the fascia that they are drilled into is just plastic....when I went to tighten the license plate screws, the screw threads just stripped-out and now I either put in larger diameter screws or figure out some other way to attach the plate. Has anyone dealt with this "annoying problem" before and is there a more secure way to mount the rear plates? Thanks.
