Re: What did you do to your Crossfire today?
Well, started the roadster to let her warm, and found the coupe dead... Should have pulled the braille battery, as it didn't seem to like being on a tender. May not get it back. Trying to slow charge it, but not much luck so far...so may be done. No luck with these little batteries. I am going back to full size. Hopefully I can find my receipt and they will warranty it. Bummer.
Update: I used the rubber mount for my Dashdaq/zeitronics, as it got cold in the garage, it fell off the windshield and turned itself on, which led to the dead battery. I jumped started the car and found it on. Turned it off, let the car run awhile after taking the jumpers off. As soon as I turned the dashdaq back on, it killed the car. Battery was dead, down to 5 volts. She will not hold more than 5 volts after charging for hrs. Got to be careful not to leave anything on while charging...lesson learned. I usually unhook them, but got lazy this year...
