Old Jan 6, 2014 | 04:36 PM
onehundred80
Default Re: P0410 secondary air injection
Originally Posted by trackprince
OK, thanks. I Googled my issue and got a lot of info, but did get the info you are giving me. as far as the emissions test, the state of South Carolina doesn't require one. but thanks, ill take a look at the relay and solder joints and move from there. its probably best i run it to an auto shop so they can properly diagnos the issue... Thanks again
If it does not need one then you can add a plate and just forget about the problem. Look it up here on how to do it.
Saves the money on fixing it.
