Thread: intermitentes
Old Jan 9, 2014 | 10:14 AM
Default Re: intermitentes
Vamos a tratar de tomar cada problema independiente. Y necesitamos entender el problema claramente.
  1. Abrir la puerta con la llave
Cuando usas el fob (control de la llave) se habre la puerta del piloto, y si le das otra vez se habre la puerta del pasajero. Asi esta funcionando? Esto es imporante entender para ver si el system central esta trabajando.
Translation.
I'm telling him that we should look at one problem at a time.
I'm asking him to first see if the doors are opening with the fob as they should. One click opens the drivers side, and second click opens the passenger. It's important to see if the central locking system works with the fob.
