Thread: intermitentes
Old Jan 9, 2014 | 08:46 PM
Default Re: intermitentes
Rekcah, you understand correctly. There's nothing wrong with his system. He only sees the issue with the key. I don't think its normal. My car doesn't open with the key. Something I need to fix. My question to you so I can relay it to David is; is it one turn of the key to open the drivers side, and a second turn for the passenger? Or one turn of the key for both doors?
David, tu sistema está trabajando correctamente del punto de electrónica, lo que estamos tratando de investigar es el problema con la llave. ¿Has intentado darle una segunda vez con la llave para ver sí the otra puerta habre?
