Re: FS: N/A Upgrade 72mm Throttle Body, Elbow and Larger MAF housing
Thanks Mr Miata, mine is the usual setup. Yes, it should fit fine even though I never used it that way. I believe the MAF housings are only different on the inside diameter. The elbow is the same size as stock but I bought it in case I wanted to play around with removing screens, baffles etc.
