Re: Ground Control Suspension Kits!!!
D Street would be good. Just did not see any Crossfires in the '14 rules and "Mercedes SLK" is in C.
I read "Substitution, addition, or removal of a single anti-roll bar and supporting hardware (brackets, endlinks, bushings, etc.) is permitted" as I can add a rear bar if the front is not changed (other than bushing material).
It also sounds like I can run 19" (standard) rear wheels on all 4 though that is stretching.
Spring must meet factory specs though may be at the limits of tolerance.
This is the biggie: "On cars without the ability to turn off electronic stability control and/or traction control (ESC/TC) from the manufacturer, modifications to defeat the ESC/TC are permitted."
