Hi!
No you aren't a jerk but it looks like I am, at the least, "misinformed". I bought the Crossfire in 2008 from a dealer. At the time I used some retirement pay to buy it and was just happy to drive it and have the dealer service it. Well, now its 2014 and I am well into retirement and have more time to play with my toys and to do things myself...in other words a lot of catch up learning. You are right, this can't be an SRT-6 cause the only turbo on it would be imaginary!
Attached is a pic of the engine cover and the exposed engine (if I did it correctly). The reason I thought I had an SRT-6 was that the manuals included with the car said so...yes I know, dumb. And yes I should have known since I have had turbo cars in the past and never experienced the kick you get with them vs a car without a turbo. But I didn't care since it was still fast and fun to drive (ignorance is bliss). Oh well, off to the blackboard to write "let the buyer beware" a hundred times!
Here is some decoded VIN info from
Home : Free VIN Decoder - Vehicle Identification Number Check and I don't see anything there that IDs my car as an SRT-6. Ill take a pic of the whole care tomorrow after it is washed and post it. Thank goodness I didn't make a fool of myself and post it on the SRT-6 site!
VIN 1C3AN65L85X040101
Vehicle Accidents/Service Get Vehicle History Report NOW
Year 2005 Engine Type 3.2L V6 SOHC 18V
Make Chrysler Driveline rear-wheel drive
Model Crossfire Ground Clearance 4.90 in.
Trim Level Roadster Limited Front Brake Type Disc
Manufactured In UNITED STATES Rear Brake Type Disc
Body Style CONVERTIBLE 2-DR Anti-Brake System 4-Wheel ABS
Transmission 6-Speed Manual Overdrive or
5-Speed Automatic Overdrive
Standard Seating 2
MPG Hwy 25 - 28 miles/gallon Optional Seating
MPG City 17 - 21 miles/gallon Tires 225/40R18
Dealer Invoice $35,276 USD Wheelbase 94.50 in.
MSRP $38,195 USD Curb Weight 3174 lbs
Trim Level Roadster Limited Manufactured in UNITED STATES
Body Style CONVERTIBLE 2-DR Engine Type 3.2L V6 SOHC 18V
Driveline rear-wheel drive Tank 15.90 gallon
City MPG 17 - 21 miles/gallon Highway MPG 25 - 28 miles/gallon
Anti-Brake System 4-Wheel ABS Steering Type Recirc
Front Brake Type Disc Rear Brake Type Disc
Turning Diameter 32.20 in. Front Suspension Ind
Rear Suspension Ind Front Spring Type Coil
Rear Spring Type Coil Tires 225/40R18
Front Headroom 37.30 in. Rear Headroom in.
Front Legroom 42.70 in. Rear Legroom in.
Front Shoulder Room 52.70 in. Rear Shoulder Room in.
Front Hip Room 53.30 in. Rear Hip Room in.
Curb Weight 3174 lbs Curb Weight 3140 lbs
Overall Length 159.80 in. Overall Width 69.50 in.
Overall Height 51.80 in. Wheelbase 94.50 in.
Ground Clearance 4.90 in. Track Front 58.80 in.
Track Rear 59.10 in. Cargo Length in.
