Old Apr 22, 2006 | 09:27 AM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: Seat Heater Repair
Originally Posted by ben47
Now, showing my lack of knowledge of upholstery techniques... why do you say the cushion should of been changed too? Shouldn't a replacement cover fit just as snug if installed properly or is it as I suspect, some of the foam was damaged and hence the ill fitting corners?
Did your dealer decide on his own to change out your seats as a complete unit instead of just the seat cover or was it as your insistence?
the dealer stated, this is the way it is to be completed (foam/leather combo). could be at the dealers discretion... i'm not sure.
i would ask for new foam to be used and redone to oem quality standards. the original foam may even be damaged when disassembled. i would call a local upholstery shop to gain some insight.
regardless... i would be pissed as well.
i indeed see the area you are referring to below:
one thing i will do... is protect the door frame from dealer damage. it seems many are having the door jamb scratched by the lower metal seat brackets during re-install of the seat.
