Old Jan 20, 2014 | 04:20 PM
  #2064 (permalink)
amx1397
Originally Posted by Chuck A
Finally had some time in the past month to fiddle around:
I have a used 2006 limited coupe which I bought in April 2013 at which time it had 18,800 miles.
Restored the headlights-they were not yellowed but badly oxidized and scratched which I found odd as the rest of the car is mint! Used the 3m manual kit and the results were awesome.
Changed the oil and I noticed a second screw in the oil pan (roughly half way up the pan on the driver side) with a tiny leak-I have no idea what is for but I tightened it in hopes of stopping the leak-anyone knowing more about this please chime in!
While changing the oil I noticed that the trans oil was leaking but I couldn't get to it with just the front end ramps so after some thought I went to Lowe's and bought (2) 2x12's 10 feet long (2) 2x12's 8 feet long and 6 cement blocks (total cost about 35 bucks) and made myself a ramp which worked perfectly! After inspection I have to assume that the problem is more of a weep than a leak as I never really nailed down the source. Alarmed by this I didn't want to drive the car without knowing the trans oil level was okay so I decided to just change it as well-for those who may want to check you're level- you will need a 14 mm hex head for the fill and a 17 mm for the drain (got the kit at auto zone for 12 bucks) also note that the fill is in a tight spot so I actually had to cut off about a half inch of the 14mm hex socket with a cutting wheel and it fit great. The fluid was a bit low but it took 8 years so I'm not gonna worry to much about it till I can actually see oil spots on the garage floor!
I researched what oil to use right here on the good ole forum-went with non-synthetic
5w-20 which is basically stock! If any other members have had this weep-leak problem I love to hear about it!
Lastly I threw in a couple lifetime K&N air filters.
Next will be the leaky valve covers-I'll research that here on the forum as well!
Love this car!
chuck A are we talking about a crossfire or something else,
because to change the oil ,there is a drain plug (not removing the pan) and it takes 9 qts. of Moble 1,, 0-40 synthetic, it says that under the hood.and the oil filter (from the top of the engine) should be fleece. if this was my car the non synthetic oil would be out of there even if i had to drain it on the floor.
to change the tranny oil ,yes remove the pan,,when it was off remember that electric connector that is what licks on almost every car,,the o-ring has dried out .
don't know what screw you are talking about ( unless it was that loose screw removing the pan.) LOL. jim
