Old Jan 22, 2014 | 03:19 PM
  #49 (permalink)
onehundred80
Default Re: Johnson CM30 = Damaged Intercooler?
Originally Posted by syfi
I totally agree. If using separate fluid types then by all means integrate a separate tank. Many who bought the separator kit aren't worried about that and this was just another solution. Any common sight glass made with borosilicate glass won't discolor or fog up, despite 180s concerns. If they did, you wouldn't see them used on many motorcycles as oil level viewers now would ya. This was just a thought to give those with no separate tank some peace of mind.
A site glass used as a level indicator is different to one with nothing but fluid traveling through it. You cannot see the fluid moving unless there are bubbles or some other change in color in the fluid, you just see that there is something there. Over time the glass will get a build up as will the hoses and engine block, not thick but enough to obstruct any view of bubbles etc.
A site glass is a waste of time in my mind. I just open the valves and let the fluid fill up the system sometimes, needed or not.
I guess we can agree to disagree on this matter.
