Old Jan 22, 2014 | 07:24 PM
grip grip's Avatar
grip grip
Default Re: got a x90 4 wheel drive
Check this one out. The guy must have 15k tied up in it.
96 Suzuki X90, offroad modified.
Here's the list of mods:
Mods all done by me-
frame extended to 99", frt and rear stretched
Toyota diffs front and rear, 5.29 gears locked on both ends
spring over, rear revolver shackles
4 whl disk brakes, braided extended brake lines
F250 frt shock towers
2" lift yota spring packs w/u bolt flip
Marlin crawl box, dbl transfercases, yota transmission with a Ringr adapter
Yota modified clutch, new Zuki pressure plate and TO bearing
autometer oil and water temp gauges
Cavalier seats w/modified seat frames
glass pack muffler
custom transfercase mount
Yota ifs steering gear w/Zuki p/s pump. Homebuilt pressure hose adapter
a/m extra capacity p/s reservoir, p/s cooler w/electric fan, royal purple a/t fluid in p/s pump
homebuilt frt stinger w/6" black flutted Hellas
4500 lb badlands winch
35" tires on 10" wide steel wheels
OTT steering w/heavy t rod ends
custom cooler console
Trail Gear Yota sas kit
3" rock rails, transfer case skid
Full size new 35 MT spare in trunk
Probably forgot some stuff
