Old Jan 24, 2014 | 02:44 PM
blueeyes147's Avatar
blueeyes147
Default Re: misfire not detected appliance bosch for the diagnosis
Josh is saying :
1. Replace the MAF sensor. ( Mass Air Flow sensor )
If that does not resolve the issue, then
2. replace the CPS ( Crankshaft Position Sensor )
3. replace the Camshaft Position Sensor.
4. Use some method that detects vacuum leaks to ensure none exists.
One method is to use an UNLIT propane torch and pass it close to any suspected source of leak, if the engine smooths out, you found the leak.
BE VERY CAREFUL WITH THIS, AS YOU ARE INTRODUCING AN EXPLOSIVE ELEMENT INTO AN AREA WHERE SPARKS MIGHT EXIST !!!!!!!!
I disclaim any responsibility if you or the mechanic chooses to use this method.
so most of the parts to be inspected and possibly replaced all sensors are not mechanical parts?
