Old Jan 25, 2014 | 09:30 PM
oledoc2u
Default Re: Jacking the Crossfire??
Just under the rocker panels, both front and rear, are square little pads. These are the jacking points. I use a small piece of 2x4 lumber between the jack pad on the jack and the pads on the car. As James stated. You can use the front jacking point to raise the front and the rear at the same time. But if you are going to be yanking on things, I suggest backing that up with jack stands so the car is solid while in the air.
