Old Apr 23, 2006 | 11:31 PM
FirebaseD's Avatar
FirebaseD
Default Re: Here is a free HP increase for your XFire....
Originally Posted by cindy2
I owned a Fiat Spyder that this was done with; with the exception it was disconnected altogether. It caused a buildup of pressure and eventually blew a head gasket; overheated the engine; and warped the heads. The engine had to be replaced. The car had only 5,000 miles on it at the time. Maybe it was a particular problem with the double overhead cam FIAT; but it could be an expensive test.
Are you in freaking sane? Please give supporting information that disconnecting the vacuum hose from the ERG Valve could cause such damage... I've done this type of vacuum hose disconnect from the ERG Valves starting way back in '68, I'm sorry but such a statement on your part is so far out in left field it blows my mind... just stop it.
