Old Jan 27, 2014 | 09:32 AM
rayth's Avatar
rayth
Default Re: Jacking the Crossfire??
As others have said, jacking the car up high enough on one of the pads should lift both tires and give you enough room to slide a jackstand under the back... how to get a jackstand under the front, then, is a different story... As always, undue the bolts while on the ground and put the wheel you take off under the frame so that if the car falls with the wheel off, it will land on the wheel (damaging it, of course) and not on the suspension on the ground..
