Heated seats question.
I have a few questions about the heated seats. First is does only the back heat up or is the bottom of the seat suppose to heat also? Only the back for me heats. Kinda seems odd for only the back to heat. If both are suppose to heat how do I fix it? If not then nothing to do working fine. Well that actually leads me into question number two.
This winter has been more brutal than the last ones I've had with my Xfire. For the first time when it's like 0 or below 0 degrees outside my heated seats won't work at all. When I press the button it flickers and won't stay on. If it does turn on turns off after about 15 seconds. Is this due to the weather being so cold? If so what's the point of the heated seats not to work when it's cold? Any recommendations on how to fix this?
Thanks for all the help. You guys seriously rock. I don't know what I'd do with out this forum!
