Re: 74mm throttle body on ebay
To test the TB, you can unplug the wire harness from the mounted TB and plug it into the uninstalled TB. Turn the car on and depress the gas pedal, and you should be able to see the plate open and close. I did this and have a video of it. Not sure you really need to do the test since it won't take that much time to install it and start the car.
