Old Jan 29, 2014 | 09:58 PM
BibaResto's Avatar
BibaResto
Default Re: Help me find part no. for exterior trimming around windshield
Hopefully this will work: HELP - Door handle & windshield trim removal - CrossfireForum.org
It is a link to another XF page and shows where the massive clips are located. I used several screwdrivers. I started at the join where the upper and left side meet. I started on the upper/middle part and slid a screwdriver between the glass and trim part where the clip is, then pushed the screwdriver roughly in the center and twisted it to pop the outer connection. After you go all the way around, then you have a raised ledge so that you can easily put the screwdriver in from the outside and pop the inner portion of the clips. There are three per side and five in the upper section.
A fellow on another thread said he could switch his out in five minutes (he had two sets). I probably took at the very least 45 minutes to remove mine.
Change of subject: Do any of the parts listed on the 'Chrysler Ornamentation' sheet indicate the rubber seal that goes over the front side and top of the side windows? To clarify, the seal the covers the edges of the front and upper portions of the side windows when they're up.
Biba
