Old Jan 31, 2014 | 11:08 AM
robby363's Avatar
robby363
Default Re: Hazard lights not working, indicators (flashers) are - stumped!
Originally Posted by YraggarY
Hi all,
I was hoping some knowledgeable souls might be able to assist me with the following issue:
Car is a '04 Coupe, Automatic with 80,000 miles.
My issue is that the hazard lights aren't working at all. When I press the hazard button there's no sound, no flashing, nothing. The indicators (flashers) are working fine and all the relevant lights flash when I lock / unlock the car.
I suspect it might be a relay issue but I honestly have no clue about it. All of the information I can find relates to the hazards working but the flashers not working so I'm a little stumped. I left it in to a garage to get the trunk fixed up as I had the stuck trunk issue but the mechanic doesn't want to go digging around behind the centre console and hazard control module apparently due to the location of an airbag / airbag sensor (?).
Has anybody experienced this issue before, or would any of you be able to offer any insight as to what the issue might be?
I should also mention that I have a '97 SLK 230 that I can cannibalise for hazard module parts if they'd fit, so if that's an option I'll gladly go for it.
Would hugely appreciate any responses, thanks guys!
I'm not 100% sure but I think the relay is built into the hazard flasher switch assembly so you would have to replace the switch.
