Old Jan 31, 2014 | 04:34 PM
kjwinston's Avatar
kjwinston
Default Re: first Mystery 2007 Roadster Answer found!!!!
I asked...and Asked again...and asked Again one more time. No one knew of the mystery: "my high beams don't work by selecting the lever ON for high beams? So I had to go to the Chrysler dealer! YIKES!
Well there is a problem and it is not the Fog lamp issue. Yes if your Fog lamps are on your high beams will not come on at the same time, but will come on and turn off the fog lamps automatically.
What is bad is in your turn signal. Yes they have to open the steering wheel (dang Bags) and replace Part Number #5098519aa the switch turn signal. Try to buy the part first otherwise good ole Chrysler will charge you $359.10 for the part. It took these guys 4 hours to replace it.
They work just fine now. I am sure it would be cheaper if someone would have know, so I am passing this on. You guys have always given me great advice, and now I am returning the part number and what has to be replaced. I hope this helps!
That was a Chrysler part number.
Just put on my 36000 mile on the Toy!
KJ
