Old Jan 31, 2014 | 07:09 PM
onehundred80
Default Re: "passing blinker" mod
Originally Posted by hem1tp
okay, so I got the kit in today and started messing w/ it. I think the signal needs to be interupted between the hazard switch and the flasher but as they are a closed unit I am having difficulty. I have been messing w/ it for about 3 hours and am kind of brain-fried and cross-eyed now! So I am open to any suggestions right now; I have figured out pins from the connector 1,2 are turn signals brown wire is ground so that's 3 of 5 wires I need to assign! its the last 2 that are frying my brain. I think i need to interrupt them before the module like I said but I am open to suggestions. the peach link above shows what I'm working with but I actually have additional connectors that I can splice in or remove as needed. This shouldn't be as hard as I'm making it but like I said I'm over thinking it and messing myself up...
Any constructive suggestions are welcomed...Tim
Hi, I am not into the wiring of such items but I Googled 'comfort turn signals' and there is a lot about wiring them up.
I'm not sure if this helps but I tried.
