Old Feb 4, 2014 | 09:42 AM
B1gfun's Avatar
B1gfun
Default Re: winter rims messed up the ebrake assembly?
Yes they have, I have no trouble with bolts as long as they are the correct length.
The OP's problem has occurred many times here. The OEM bolts when used in steel rims cause a clicking noise when the wheel is rotated. The bolts used here must have been even longer causing more interference.
We know from the days of the cold war that the USSR invented everything, these days I guess that claim would be made by North Korea.
Yes 180 I used the stock bolts. (40mm shaft/60mm total length) The Mercedes rim s are thinner, thus i should have used a 20mm spacer or shorter lug studs/bolts(22mm shaft length).
Im hoping I didnt mess up the ebrake hardware. i will update and post back when I take everything apart.
