Old Feb 4, 2014 | 11:40 AM
g3air's Avatar
g3air
Default re: "Rebuilding the convertible top hydraulic system"
Originally Posted by Leptronjohn
G3air,
I am still working on the problem for you. I down loaded the manual and have been trying to understand the entire operation of the top. I do not have a solution yet but unless you are in a hurry we (the group) will come up with something. I need to understand the operation for my own use also and am going to replace my top soon. this may give me insight to your problem while in the frame work.
john.
John, you (and the Crossfire Forum Group) are very kind to stay involved and I am not in a hurry. Thank you all for your help! I am able to lower and raise the top manually now (thanks to the forum) so there is no need for haste. I just have the feeling that the fix, when identified, will likely mean I have to enlist a competent mechanic's aid, and the only place I see that coming from is the dealer, since I don't have any easy way of identifying other local sources.
