Thread: Front disc wear
Old Feb 4, 2014 | 07:52 PM
maxcichon's Avatar
maxcichon
Default Re: Front disc wear
In general, this condition indicates a bit of "drag" on the caliper pins. When you press the STOP pedal, the caliper SHOULD center itself. If the pins are not properly lubed, the caliper will push harder on one side.
Disassembly, lubrication, and machining the rotors will fix this. If you need to, replace the pads if too thin!
