Old Feb 5, 2014 | 12:49 AM
onehundred80
Default Re: winter rims messed up the ebrake assembly?
For putting the wheels back on, I made some guide pins from some bolts. Some years ago I made a bunch and gave them out at a GTG. Here is sample of what you need. Two work best. If IRC, this is the size but I would have to recheck.
Stud Guide Pin Wheel Tool 12 x 1 5mm Mercedes BMW Item ZDM10111C | eBay
If you insist on using two studs like this it is easier to have one stud an inch shorter than the other. You put the wheel on the longer stud and use that as an axis to align the second hole and the shorter stud.
It is easier to align one hole than two.
