Old Feb 8, 2014 | 11:59 AM
onehundred80
Default ESP/BAS, ABS and CEL lights
NOT MY CROSSFIRE.
My 300 had the ESP/BAS and ABS lights come on when my wife was driving it yesterday. The CEL has been on for ages and it is a Short Runner Valve problem (P1004), I may have fixed that finally this am. The valve is turned by a solenoid and the valve gets stuck up in some cases, mine was jammed and I cleaned and freed it with carb cleaner, so hopefully it works. If not its $150 for the solenoid. I cleared the CEL but the emissions light says fault pending, hopefully a few drives will clear that.
The big shock is the ESP/BAS and ABS lights coming on all at once, I searched on the 300 forums and found nothing specific. Curiously no codes were set for these problems. So has anyone any ideas?
I have three weeks until both cars are due for the emissions test and it will not even be tested with these lights on.
Meanwhile I'll keep searching.
Answer?
Ask the right question and you get an answer, wheel speed sensor. If so which one?
