Old Feb 8, 2014 | 11:59 AM
harbor's Avatar
harbor
Default Re: replace engine coolant
Originally Posted by dtinker
I think I am just going to drain and flush with engine running so T-stat opens up, etc. I noticed that the pics show changing out the t-stat and gasket. I don't think I will do that unless some really good reason. Car does not get hot, t-stat works fine, no leaks. I assume this is changed more for inspection than for anything else. I am going to buy Zerex GO-5, HOW MUCH SHOULD I buy? I think I will buy the 50-50 premixed, does it take 3 gals?
Coolant system takes just under 12 quarts, so you're good with 3 gals of mix.
