Old Feb 9, 2014 | 05:11 PM
ala_xfire
Default Re: ESP/BAS, ABS and CEL lights
That shows six pins and mine has five pins, pin five in the diagram is missing.
I really do not understand the diagram, Does it say I should touch pin one with 12 volts and ground the body?
I am not in to sparky stuff as too often I get sparks when I shouldn't.
Service manuals often tell you how to check individual components electrically, quoting voltage in the plugs ans resistance in the socket, my manual does not even mention the P1004 code. The Crossfire manual may be a bit vague in spots but seems to have the bases covered generally.
I'll go look at my old LH manual and see if the same part shows up there.
Dunno - just found that on the web.
I do have the AllData for my '02 Concorde Limited, but it's a 3.5.
Is your 300 a 3.5 v6, or a Hemi ?
( 300C might mean it's a V8, I don't know 300 stuff )
