Re: my stupid mistake
My wheel bearings were fine hitting a curb at 50 ish...
OP pull all 4 wheels off and check that side vs the good side. Guarentee your front outter tie rod on the drag link is bent, and your tie rod on the rear is bent (meant to take the impact, so that everything else doesn't), but you need to check if everything else looks good. While praying, inspect your rear subframe where the control arm mounts (compare to other side if it's bent forward), and front lower control arm.
Good luck.
