The Iceman Cometh
Feb 10, 2014 | 03:41 PM
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: The Iceman Cometh
Quote:
West Peterson
My car is a Base, and I think that wasn't a feature available. Am I wrong? There was no fuse, and there doesn't appear to be any circuit a fuse would connect to in slot 12.
Heated nozzles were not available on the base models.
If you had fluid with antifreeze in it you should have had no trouble at those temps.
The hoses can get plugged with slime and gunk over time, this can get into the nozzles and plug them, also the gunk can clog the outlet from the bottle if it is a lot.. Working intermittently can be a hard one to cure.
I have had problems on some cars where a little bit of ice gets on the nozzle and blocks it, but two at once, not so common I would suspect.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
