oledoc2u
Josh, if you kept your car at 3300lbs...that is pretty good. We have several ag scales around the plant where I work, and I have forgotten my numbers now, but both are under 3300lbs...The roadster is heavier obviously...
Remember I started with an NA, manual trans coupe (3010) and shaved 70+lbs with my seats. The motor only added 50-80lbs. With my exhaust chopped off I'm probably right around 3000 lbs even.
