Re: The Iceman Cometh
oledoc2u
It is freezing at the jets. I would pull the hoses, blow some air down thru them into the tank. This will clear anything that might be shoved up against the jet helping it to freeze. Doesn't take much....as the wind chill is well below freezing....at 30° outside...line needs to be clear all the way to the jets for it to clean out. Tanks are impossible to clean so good luck.
Wind chill only makes you feel colder, it cannot reduce the temperature of anything below the ambient temperature.
I took my tank out and thoroughly cleaned it, it was filled with slime.
I'm assuming that the fluid I used had antifreeze in it, but maybe I assume too much.
Blue stuff in a bottle? OK, we can work on this ..............
What did the label say?
