Lenin
If you used A0061539928 in place of the A0051537228, and you did not reprogram your ECU to re-scale the signal, then that is your problem. Both sensors operate at 0-5v. So, the same PSI in the new and old sensor will translate into a different voltage readings and will confuse the ECU.
Hi,
You are absolutely right about this. I have reprogramed the ECU though.
Thanks for the heads up
/Adam
