Grubnut
I believe that moving the header tank is simply removing 1 or 2 10mm bolts and pulling it clear of its locating plugs. This would save you a lot of blood sweat and tears. I'll try and take a look this evening.
Yes i looked at it but with the hose which runs into the bottom of the tank restricting its movement I was concerned that I may end up having to lean the tank over quite a bit to get it out of my way and so possibly introducing an airlock into the cooling system which would have been another problem to sort out.
