Old Feb 16, 2014 | 12:13 AM
Billy22Bob's Avatar
Billy22Bob
Default AVT Bosch Intercooler Pump
I may be up for a IC pump
Found these over on Ebay.
Seem to pack a bit more punch than the Johnson30 and look a lot more like the original.
I also like the look of them since their larger diameter means they wouldn't have to work/rev as high as the Johnson to achieve the end game (flow and pressure). Last longer????...maybe
But the only specs listed are - 1,200-1,700lph up to 5psi. So I'd figure the 5psi would be for the 1,200lph (5 USGpm) figure...?
.....but capable of 8psi - I'd think this means dead head....?
More specs would be good if anyone has them..
It's not as long in the legs as the Johnson CM90's, but with the restrictive IC and stock HX, long legs aren't what's needed here, psi head is. Because of this I'm guestimating it might even pull more water than the 20mm CM90 in a stock application.
Need to check the AWG's for the Amps and see how the 5A fuse handles it - just to keep it safe.
Anyone tried - thoughts?
I don't need to be convinced of the popularity of the Johnson CM30 (or CM90) - Just looking for people who have looked at (and maybe even discounted), but might have dug up some detail on these AVT pumps.
Yes - they are a little more expensive
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270965688820
