nautiquess
They said that OEM ones were junk and hard to find and said that we needed to do the aftermarket upgrades in order to get it in.
They were probably refering to the OEM original bolts that came on the car from the factory. They only allow a little adjustment. The aftermarket/OEM eccentric bolts will allow +/-1.5 degree adjustment which should be plenty to get you in spec. The OE p/n is just Mercedes putting their name on it and doubling the price. The Febi-Bilsteins are essentially the same bolts as the OEM Mercedes eccentrics. The Febi ones I got from AutohauzAZ were stamped with DYTSA which is a well respected vehicle bolt mfg. You're better off sticking with the Febi price wise.
||- D Y T S A -||
