Re: Crossfire Engine Knock at Low Idle
By the way, did I fail to mention that mine is automatic?
Annoyances update:
1. Window wind noise: inserted a rubber tube inside the weather strip that is between the driver window and the roof/windshield area. Also adjusted the window's angle to lean more towards the weatherstrip using the nuts on the bottom of the door. Seemed to help a little.
2. Headlight fogging up: there is actually a bulletin on this. Silliconed the headlight vents, thought it would be the same as putting caps on them. Still fogging up. Maybe there is a crack somewhere.
