Old Feb 19, 2014 | 06:09 PM
ala_xfire
Default Re: License Plate Lights Problem -- Blown Fuse?
Originally Posted by kragath
Allrigth... Problem solved! Everything is running perfectly now and I didn't have to do anything to led bulbs. Thanks ALAXFIRE!
BUT... There was one thing I noticed that I should have taken picture from. The cardboard list under the cover that shows fuse numbers was incorrect. It said that license plate light should be on "hole" number 6. I checked it and it wasn't broken. Then I started to check every fuse starting from 1 and finally found the broken one from "hole" 11 (same as SMOKEY847 did).
Is this common mistake or...?
And if it is... Is there any other known mistakes on "fuse manual"?
From the repair manual :
OPERATION
The Fuse Block on the side of the Illumination Control Module houses the Fuses for the following:
Fuse 2. Brake Lamp
Fuse 3. Right High Beam/High Beam Indicator Lamp
Fuse 4. Reverse Lamp/Turn Signal Lamp/Rear View Mirror
Fuse 5. Left High Beam
Fuse 6. Right Low Beam
Fuse 7. Right Parking/Tail Lamp Side Marker
Fuse 8. Left Low Beam
Fuse 9. Fog Lamp
Fuse 10. Left Parking/Tail Lamp Side Marker
Fuse 11. License Plate/Instrument Cluster Lighting/Symbol Lighting
From the owner's manual :
