sk8erjosh09
It's not the starter... Best way to check is to ground the violet wire that runs to connector 4, pin 25 to see if the starter spins.
I'm not to sure what they are doing. All I know is that they will take out the starter motor out, have a look at it and see what happens. I guess if the starter motor is fine once its checked over, I know to order a RCM.
All I know so far is that they have touched up the soldering and put it back in. The battery is healthy and has more than enough power to start it. I will be back at home tomorrow, so will be with the car all weekend.
Thanks
