Old Feb 20, 2014 | 01:37 PM
Padgett's Avatar
Padgett
Default Re: Crossfire cut out - engine won't start! Help please!
Don't feel bad, I'm a little confused also. Looking at the starting circuit on page 8F-42 in the 2005 FSM I see a violet wire coming from 1F on the Pulse Module, through C106 (bulkhead conn) and to the starter solenoid coil (50). Doesn't this wire need 12v applied to spin the starter or is the diagram wrong ? YWTK
Looks like if you ground C4-25 on the PCM it will do nothing at best and short out the ignition switch at worst. Am I missing something ?
