Old Feb 20, 2014 | 05:18 PM
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Crossfire cut out - engine won't start! Help please!
Originally Posted by Padgett
Sounds English: put the fuse on the ground side so the component will protect it. Solenoid just needs 12v, doesn't really matter which is ground but the motor better have the polarity right
ps when I spent $60 for the '07 FSM I thought about another $90 for the Wiring manual but decided against.
No neet to protect anything when grounding that wire. It's protected already by the pulse module. The ECU literally only grounds it, nothing else.
Good thing you didn't, it's horrible. The Mercedes diagrams are much harder to read, but it's because they're that much more thorough.
