Re: My P0410 secondary air code fix
I also had luck polishing the relay contacts, but that is also a temporary measure. Do we know if the low voltage that causes the relays to carbon up is generally a result of the solder joint issue, or is this usually due to the crossfire being especially picky about battery health?
