Old Apr 30, 2006 | 05:53 AM
bobs's Avatar
bobs
Default Re: tire pressure monitoring system
Alain, the 2005 Base model does not come with the tire pressure monitoring system. I'm not sure what would be involved to get it re-activated, but my guess is that you would need to buy a pressure sensing valve stem for each wheel and the system's "brain" which sits in the pod that the rear view mirror is mounted on.
There are also several aftermarket systems you could try as well.
