Old Feb 28, 2014 | 09:16 AM
  #60 (permalink)
Padgett's Avatar
Padgett
Default Re: ESP/BAS, ABS and CEL lights
When you say "exciter", do you mean the toothed wheel in the hub or on the axle ? Barring an accident these rarely fail since there is nothing to wear and they are steel. I have seen them get clogged and need cleaning but that is it.
The sensor OTOH is a hall effect trigger that also rarely fails however the weak point is the sensor wiring (something in the Florida air loves to eat rubber). The fronts particularly move with the wheel and the cable is liable to crack. I keep a can of marine "liquid rubber" around to teat ABS sensor wiring. Sensor should be in the $60-$90 range.
Am not surprised that the error codes might be less than accurate, if a wheel sensor is indicated, first thing I do is to raise the car, remove the wheels, and check for a cracked, frayed, or twisted sensor lead. The defect is usually quite visible.
