Old Feb 28, 2014 | 01:23 PM
ala_xfire
Default Re: Both ear drums busted.....
Replacing the RCM relays is not for the faint of heart, or an inexperienced electronics technician with the proper un-soldering equipment,
besides, the only relay that should even NEED replacing is the secondary air pump relay.
All you should be concerned with is cold solder joints ......
What is the original issue that is causing you to eyeball the RCM ?
